The latest eWeLink App V5.14 update introduces powerful new features designed to enhance your smart home experience. From seamless device control within live camera feeds to more flexible scene settings and expanded widget support, these updates make smart home management even more intuitive. Let’s dive into the highlights!
Ever wanted to control your smart devices while keeping an eye on your live camera feed? Now you can! With the new update, you can link devices to your cameras within the Insight -> Camera Live View section. This allows you to turn lights on or off, activate switches, or trigger other devices directly from the live feed screen.
For example, if you have a camera monitoring your front door, you can now unlock the smart door lock or turn on the porch light with just a tap—all without switching screens. This seamless integration adds convenience and security to your daily routines.
Newly Supported Devices of This Function Include:
Device Type |
Eligible Device Models (Examples) |
Single-Channel Plug |
SONOFF BASIC_R3 SONOFF MINI SONOFF RF_R2 SONOFF S20R1 SONOFF S26 SONOFF S31 Lite SONOFF S55R1 SONOFF S30 AIB-xU1 CKCP-001 |
Single-Channel Plug_Support 2.4G eWeLink-Remote |
SONOFF BASICR4 SONOFF MINIR3 SONOFF MINIR4 SONOFF S40 lite CK-BL602-4SW-AY |
DIY Smart Switch |
SONOFF Basic SONOFF RF SONOFF SV |
Single-Channel Switch |
SONOFF RF R2 SONOFF T1 1C SONOFF Touch SONOFF TX1C |
Four-Channel Plug |
SONOFF 4CH |
Power detection Plug |
SONOFF IW100_US SONOFF IW101_US SONOFF Pow R2 SONOFF POWR3 SONOFF S31 PSA-X67-GL |
Three-Channel Switch |
SONOFF T1 3C SONOFF TX3C |
Dual-Channel Switch |
SONOFF T1 2C SONOFF TX2C |
Thermostat |
SONOFF S22_CN SONOFF TH10 SONOFF TH16 PSA-BHA-GL |
Dual-Channel Plug |
SONOFF DUALR2 |
Multi-Functional Dual-Channel Power Detection Switch |
SONOFF DUALR3 |
Power Monitoring Plug Overload Alert – Multi-Channel Protocols |
SONOFF S40 SONOFF S40TPA SONOFF S40TPB |
Single-Channel Plug-Multi-channel version |
SONOFF Micro |
(POWCT)POWR3 – with LCD Screen |
SONOFF POWCT SONOFF POWR316 SONOFF POWR320D SONOFF S60TPF SONOFF S60TPG |
Temperature & Humidity Monitoring Switch_Support with History Feature |
SONOFF TH16R3 |
RGBCW LED Bulb Light, with 2.4G eWeLink-Remote |
SONOFF B05-BL CK-BL602-5PWM-01 |
HMI Wall Switch |
SONOFF NSPanel |
Four-Channel Plug_Support 2.4G eWeLink-Remote |
BL1-S04-01 CK-BL602-4SW-HS |
Zigbee Smart Switch |
SONOFF S26R2ZBTPG |
Smart Plug with Power Monitoring |
SONOFF Pow |
Curtain Motor |
CK-BL602-DDCL-01 |
Creating and managing smart scenes just got easier! You can now copy a Manual Scene directly from its editing page, eliminating the need to recreate one from scratch.
Imagine you’ve set up a scene to turn off all the lights and appliances before bed. Now, if you want a similar scene for leaving home, you can simply duplicate the existing one and tweak the details. This feature saves time and makes automation setup effortless.
More flexibility in smart scenes! Certain switches and lights can now function as both a Trigger and an Action within the same smart scene.
For instance, you can configure a smart light switch so that when it is manually turned on, it not only activates another device (e.g., a smart plug for a coffee maker) but also turns itself off after a set period to conserve energy. Similarly, a dimmable smart bulb can be set to increase brightness when motion is detected and then automatically adjust to a lower brightness after a few minutes.
This expanded capability enhances automation possibilities, allowing for more dynamic and responsive smart home setups tailored to your daily routines.
Device Type |
DIY Smart Switch |
Wi-Fi Smart Switch with Energy Monitoring |
Temp & Humi Monitoring Smart Switch |
SONOFF Micro |
SONOFF S26R2ZBTPG |
SONOFF Pow |
GSM Single-Channel Plug – Multi-channel protocols |
GSB-MSW-01 |
Rhythmic Strip Light |
SONOFF L1 PSF-BTA-GL |
Dual-Color Cold and Warm Light_Support with tuning and scenes |
SONOFF B02-B SONOFF B02-F |
RGBCW LED Light_Support with tuning and scenes |
SONOFF B05-B WTW-SNL-05 |
Zigbee Single-Channel Switch _Support OTA |
SONOFF ZBMINI-L SONOFF ZBMINIL2 |
Wi-Fi Smart LED RGB Light Strip |
SONOFF L2 SONOFF L3-5M OPL-LED-01 SN-OPL1200-L3RGB |
Wi-Fi/2.4G 1C Plug, support eWeLink-Remote Gateway |
CK-BL602-4SW-HS-02 |
Wi-Fi Smart Dimmer Switch |
SONOFF D1 SONOFF D1R1 SONOFF Dimmer PSF-BLA-GL |
RGBCW LED Bulb Light |
SONOFF B1 CKDK-001 LA-5CUI |
ZigBee Smart Plug |
SONOFF ZCL_HA_DEVICEID_MAINS_POWER_OUTLET2 |
Android users can now create Device Control Widgets (2×2, 4×2) for an even wider range of devices. With this update, roller shades, Zigbee tunable white lights, roll-up doors, and more are now supported.
Device Type |
Roller Shades |
GDM-001 PSF-BTA-GL |
Zigbee Color Tunable White Light |
Roll-up Door |
CK-BL602-TC-01 |
Zigbee White Light |
Zigbee Tunable White Light |
These widgets provide instant access to frequently used devices right from your home screen. For example, you can open or close your roll-up door without needing to launch the app, making daily operations more efficient and convenient.
This update enhances the usability and efficiency of your smart home setup, offering more ways to interact with your devices. Upgrade to eWeLink App V5.14 today and experience smarter, faster control like never before!
eWeLink App version 5.14 has been submitted to the Google Play Store and it will be accessible gradually. iOS users can anticipate the release by the end of March. Stay tuned for an elevated smart home experience!
