eWeLink Cast allows you to create up to 5 dashboards and to switch between them on a single tablet, when you display a dashboard on your tablet and don’t want others to switch to another, try setting PIN code, if the dashboard is PIN encrypted🔒, you will need to enter the correct PIN code🔑when entering it.
When you‘re creating or editing the dashboard on eWeLink web, on the settings page, there’s an optional PIN code setting at the bottom left, fill in a 4-digit code and the dashboard will be encrypted.
This is helpful when you display a dashboard for everyone including guests and want to keep other dashboards private.
