Aqara has been releasing Matter bridge features to most of its hubs and Zigbee gateways to connect its switches and sensors to Matter-supported platforms, including eWeLink. This guide will walk you through the process of pairing your Aqara devices with the eWeLink ecosystem via Matter.
Prerequisites: Before you begin, ensure that you have the following:
1. Open the Aqara app and navigate to the Accessory tab.
2. Tap on the Matter hub you want to integrate with eWeLink.
3. Tap the three-dot button on the top right corner to enter the settings page.
4. Find the “Expose to Matter” option.
5. Tap Matter Pairing Code to generate the setup codes for steps on the eWeLink app.
6. Launch the eWeLink app and tap the “+” button in the top-right corner.
7. Select “Scan” from the available options.
8. If you only have one phone, please copy the code from the previous steps and tap “No available QR code, add manually” on the code-scan page.
9. Paste the pairing code obtained from the Hue app into the input field and tap “Next.”
10. The eWeLink app will check the status of your network and Matter Hub. Once everything is verified, the bridge will be added to your eWeLink ecosystem.
11. The app will then prompt you to rename the bridge and its sub-devices and assign them to a room. If you skip this step, you can always rearrange them later.
> Extra Tips for Android Users:
Alternatively, you can use pop-ups from your phone or your system’s QR code scanner to initialize the setup, starting from step 6. Select the eWeLink app from the smart home app list. Your Android phone will guide you to add the devices to Google first and then share them with the eWeLink app.
