Make Everyday Home Routines Easier with eWeLink
Control, automate, and share your home more easily with eWeLink.
We understand how frustrating Daylight Saving Time (DST) transitions can be. You’ve probably encountered issues where device timers don’t operate as expected—whether it’s the coffee machine starting an hour late or the lights turning on early. These glitches can make your eWeLink-supported devices feel less “smart,” even somewhat clumsy.
That’s exactly what we’re aiming to fix! We are deeply aware of that. Starting March 2025, firmware updates will gradually roll out to eligible devices to automatically handle DST changes. Once updated, your devices will perform more reliably during DST transitions. Here’s how to get your devices ready:
To ensure a smooth transition into DST and avoid issues with device timers, please follow these steps:
1. Update the App
Make sure you’re using the eWeLink App version 5.13.1 or later before the DST transition. This update ensures compatibility with new features, especially by conveying the correct time zone parameters to the device firmware.
2. Check Your Time Zone Settings
Go to Profile > Settings > Time Zone and check that your time zone is set as you want.
3. Update Your Device Firmware
Visit the eWeLink home page and click on the banner to check for available firmware updates.
Keeping your smart devices up to date is crucial for optimal performance, but updating each device manually can be time-consuming. With eWeLink Web, you can upgrade multiple supported devices at once directly from the Firmware Update page.
If your devices support the latest firmware updates, log in to eWeLink Web, navigate to the Firmware Update page, and streamline your update process.
Here are some potential issues you may face during the DST transition:
1. Firmware Update Failures:
Offline Devices: If your device is offline, the firmware update won’t be completed. Please make sure your devices are online before attempting the update.
Firmware Upgrade Duration:
Wi-Fi devices usually take around 5 minutes to update.
ZigBee devices may take longer, varying by device. For example, updating the water valve or radiator valve may take 1 hour due to the Zigbee mechanism.
Stuck at “Updating”: If the update gets stuck, try deleting and re-adding the device to resolve the issue.
Older Devices: Some older devices might be limited by the chip’s capabilities and have trouble with firmware updates.
Note: Manually adjusting the device timers is also available. If you don’t want to update the firmware or have other thoughts, check this guideline HERE.
2. DST-related Timer and Data Issues:
Incorrect Timer Execution: If the firmware and eWeLink app are not updated as suggested before DST, your device might use the wrong time, causing timers to run at the wrong time.
Power Consumption Logging Issues: Devices without the latest firmware may log energy consumption with a time discrepancy of one hour (e.g., showing 7:00 PM instead of 8:00 PM), leading to inaccurate charts.
Device Sharing: Timers for shared devices will follow the owner’s time zone. Any changes made by the owner will be reflected for all shared users.
3. Mismatch Between Timer Actions and App Time Display:
If your phone’s time zone is changed (e.g., due to travel), the change won’t affect device functionality. However, the local time for device timer actions may not match the time shown in the app due to the discrepancy.
4. DST Timer Execution:
If you have timers set around or exactly at the time of the DST transition, they may not execute exactly as expected on the transition day.
As you may know, firmware development is a time-consuming process, so updates will be rolled out in stages. We appreciate your patience and understanding.
The firmware for all devices below will gradually be available:
ID | Firmware Model | Firmware Version for DST | Eligible Device Models (Examples) |
1 | SN-NG-ZBP-01 | 2.4.0 | SONOFF ZBBridge-P |
2 | SN-ESP32C3-S60-01 | v1.2.0 | SONOFF S60TPF SONOFF S60TPG |
3 | SN-ESP32D0-THR3-01 | v1.3.0 | SONOFF THR316D SONOFF THR320D SONOFF THR316 SONOFF THR320 |
4 | E32-2SW-P0 | v1.6.1 | SONOFF DUALR3 SONOFF DUALR3 Lite |
5 | SN-ESP32D0-POWR3-01 | v1.2.0 | SONOFF POWR320D SONOFF POWR316D SONOFF POWR316 |
6 | SN-ESP32C3-BASICR4-01 | v1.1.0 | SONOFF BASICR4 |
7 | SN-ESP32D0-POWCT-01 | v1.3.1 | SONOFF POWCT |
8 | PSF-B01-GL | v3.8.0 | SONOFF BASICR2 SONOFF S26R2 Series SONOFF T0/T1/T2/T3 Series (1C) SONOFF RFR2 SONOFF RE5V1C SONOFF S55 Series SONOFF SlampherR2 CKCZ-006 CKCZ-005 |
9 | PSF-BD1-GL | v3.8.0 | SONOFF MINIR2 SONOFF BASICR3 SONOFF RFR3 PSF-xD1 |
10 | PSF-B04-GL | v3.8.0 | SONOFF T0/T1/T2/T3 Series (2C/3C) SONOFF 4CHPRORR2/3 SONOFF 4CHR2/3 SONOFF DUALR2 SONOFF iFan02 |
11 | PSA-B01-GL | v3.8.0 | SONOFF S26 Series SONOFF BASICR2 SONOFF SV SONOFF S31 Lite Series SONOFF RFR2 CKCZ-001 |
12 | PSA-BHA-GL | v3.6.0 | SONOFF TH16R2 SONOFF TH10R2 SONOFF TH16 SONOFF TH10 PSA-BHA-GL |
13 | ITA-GZ1-GL | v3.8.0 | SONOFF BASIC SONOFF RF |
14 | PSC-B67-GL | v3.7.0 | SONOFF POWR2 SONOFF S31 Series PSC-B67-GL |
15 | SN-ESP32D0-MINIR4-01 | v1.2.0 | SONOFF MINIR4 |
16 | PSF-BRA-GL | v3.6.0 | SONOFFRF BridgeR2 SONOFF RF Bridge PSF-xRA |
17 | PSF-B67-GL | v3.6.0 | SONOFF IW101/100 Series PSF-X67 |
18 | E32-MSW-NX | v1.6.0 | SONOFF NPanel-EU/US |
19 | SN-BL602-S40-01 | v1.5.0 | SONOFF S40 Series |
20 | ESP32D0-MSW-T5 | v1.3.0 | SONOFF M5 Series |
21 | BL1-ALL-LED | v1.7.0 | SONOFF B05-BL-A60/A19 SONOFF B02-BL |
22 | SN-ESP32D0-T5-01 | v1.5.0 | SONOFF T5 Series |
23 | BL1-S04-01 | v1.5.0 | SONOFF MINIR3 |
24 | PSF-BLD-GL | v3.6.0 | SONOFF D1 |
25 | PSF-P76-R3 | V1.2.0 | SONOFF POWR3 |
26 | PSF-BFB-GL | v3.6.0 | SONOFF iFan03 SONOFF iFan04 Series |
27 | SN-MG22-TRVZB-01 | v1.3.0 | SONOFF TRVZB |
28 | SN-MG22-SWV-01 | v1.0.3 | SONOFF SWV-NH/BSP |
29 | CK-BL602-4SW-HS | v1.6.0 | May be the same as the Firmware model |
30 | CK-BL602-SWP1-01 | v1.3.0 | |
31 | CK-BL602-4SW-WH | v1.3.0 | |
32 | CK-BL602-5PWM-01 | v1.5.0 | |
33 | CK-BL602-4SW-AY | v1.4.0 | |
34 | CK-BL602-IIC-ABC-04 | v1.3.0 |
Use eWeLink to monitor, automate, and reduce wasted electricity at home.
A quick beginner’s guide to getting started with eWeLink.
Bring order to your smart home with effortless scene organization.
