V1.14.0 (2024.4.25)
New Features:
Optimizations:
Bug Fixes:
V1.13.7 (2024.3.27)
New Features:
Optimizations:
Bug Fixes:
V1.13.4 (2024.3.7)
New Features:
Optimizations:
Bug Fixes:
V1.13.3 (2024.1.31)
V1.13.2 (2024.1.23)
New Features:
Optimizations:
Bug Fixes:
V1.13.0 (2023.12.26)
New Features:
Now you can drag and drop the scence actions to rearrange their order.
Support for adding SNZB-03P Motion Sensor, SNZB-04P Door/Window Sensor, and NSPanelP-Router.
Paral-sync add-on now supports SNZB-03P Motion Sensor, SNZB-04P Door/Window Sensor, SNZB-02D Temp.&Humi. Sensor, and TRVZB Thermostatic Remote Valve (please update Paral-sync add-on to the latest version on its detail page).
eWeLink Smart Home add-on now supports cloud control of some devices and LAN control of more sensor and light sub-devices of SONOFF Zigbee Bridge Pro. (please update eWeLink Smart Home add-on to the latest version on its detail page).
Optimizations:
Increased the limit of CAST dashboards to 10.
Optimized logic for adding, deleting, and synchronizing RF remote controllers in eWeLink Smart Home add-on.
Sidebar UI design optimized. Added an entry to open add-on page in a new window.
Bug Fixes:
Resolved the issue where the same device couldn’t repeatedly be used as scene actions in a scene.
Fixed the bug where Temp.&Humi. sensors couldn’t save 1 decimal place as scene triggers.
Fixed the occasional pairing issue with Matter Bridge.
Resolved the problem where device names changed in Matter-supported platforms after iHost was restarted.
V1.12.0 (2023.12.01)
New Features:
Bug Fixes:
V1.11.1 (2023.11.23)
Fix the problem of scene being disabled.(For scenes where the trigger condition is set to “Any condition is met” after upgrading to version 1.10.0, you need to edit the scenes and save them again.)
Fixed the problem of scenes being accidentally triggered.
V1.11.0
New Features:
Added a new feature eWeLink-Remote Control in Pilot Features. Now you can add SONOFF S-mate, R5 and S-mate2 when you toggle “eWeLink-Remote Control” on.
Now you can search for devices by device name on the device list page.
Now you can search for scenes by scene name on the scene list page.
Added support for SONOFF Zigbee Thermostatic Radiator Valve.
OpenAPI now supports the integration of air conditioners and fans.
Optimizations:
Optimized iHost update process. Now you can update iHost to the latest version without binding an eWeLink account.
Improved the display of smart devices in scene, allowing for device search and presenting devices in a categorized order based on room classification.
eWeLink add-on V1.4.0 now supports to sync sub-devices (including Zigbee switches, plugs, curtains, wireless switches, and T&H sensors) from ZBBridge Pro to iHost.
homebridge pligin V1.2.0 added support for fan lights and T&H sensors.
Optimized iHost menu bar UI design.
Bug Fixes:
Resolved the issue that Aqara Motion Sensor P1 cannot be triggered.
Fixed the bug that Aqara SSM-U01 cannot be controlled.
Fixed the issue where the IKEA TRÅDFRI Motion Sensor E1745 was not triggered as expected.
Fixed the issue with inability to control the IKEA ASKVADER on/off switch E1836.
V1.10.0 (2023.09.13)
Optimizations:
Bug fixes:
V1.9 (2023.08.11)
New features:
• New add-on tts2cube-pico is available, allowing you to convert text to speech. Guide
• Added Turbo mode in pilot features, which supports enhancing Zigbee signal by maximizing the transmit power of the iHost Zigbee module.
Optimizations:
• Now you can add Temp. &Hum. data charts, energy consumption charts, calendar widget, clock widget, and text widget in CAST.
• Support for changing CAST dashborad background colors.
• CAST layout optimizied.
• Add-on supported mounting and accessing USB serial devices.
• Added support for lights in Matter Bridge.
Bug fixes:
• Resolved the problem that Tuya multi-channel switches could not control individual channels.
• Fixed the issue that devices added via Zigbee2CUBE cannot be controlled.
• Fixed the bug that tailscale add-on could not specify a volume at runtime.
• Resolved the slow loading issue for the Temp. & Hum. data chart due to an excessive amount of historical data.
Feel free to leave your ideas or questions here:
https://forum.ewelink.cc/t/release-note-whats-new-in-ewelink-cube-v1-13-3/16376
