We’re thrilled to announce the release of the first official eWeLink Home Assistant Add-on.
Head to the installation guide, and empower your eWeLink Support devices with Home Assistant.
Log in to the Home Assistant Lovelace console (usually the URL is http://homeassistant.local:8123/), click Supervisor at the sidebar to open the HassOS dashboard, switch to the Add-on Store tab. Click the vertical ellipsis (three vertical dots) in the upper right corner, select Repositories in the pop-up menu, enter the official add-on address of eWeLink: https://github.com/CoolKit-Technologies/ha-addon in the Manage add-on repositories modal box, click ADD. After closing the modal box, you can see the newly added eWeLink add-on on Add-on Store page.
Click the eWeLink Smart Home card to open the add-on information page, click INSTALL, and wait for the installation to complete. Once it is done, click START to enable the “eWeLink Smart Home” add-on.
*Tip: You need to change the home_assistant_url if you are using docker or other versions of Home Assistant that are not Home Assistant OS.
To facilitate quick access to the eWeLink Smart Home add-on, you can enable the Show in sidebar option.
Now you’ve installed the official add-on, let’s dive into the settings part.
Read the full article >
Got more ideas?
Fill in a short Product Survey to submit your feedback >
The following list presents what eWeLink Support devices you can configure and control on Home Assistant.
| Wi-Fi Smart Switch | Wi-Fi Smart Switch with DIY Mode | ZigBee DIY Smart Switch | Wi-Fi Smart Switch with RF Control |
| SONOFF BASICR2 | SONOFF BASICR3 | SONOFF BASICZBR3 | SONOFF RFR2 |
| Wi-Fi Smart Switch with DIY Mode & RF Control | Wi-Fi Smart Switch with DIY Mode | ZigBee Smart Switch | Wi-Fi Smart Switch |
| SONOFF RFR3 | SONOFF MINIR2 | SONOFF ZBMINI | SONOFF DUALR2 |
| 2-Gang Wi-Fi Smart Switch | Wi-Fi Smart Switch with Energy Monitoring | Wi-Fi Smart Switch with Temp. & Hum. Monitoring | 4-gang Wi-Fi Smart Switch with RF Control |
| SONOFF DUALR3 | SONOFF POWR2 | SONOFF TH10/16 | SONOFF 4CHR3/4CHPROR3 |
| Zigbee USB Dongle | Wi-Fi Smart Lamp Holder with RF Control | USB Smart Adapter |
| SONOFF ZigBee CC2531 USB dongle | SONOFF SlampherR2 | SONOFF Micro |
| Wi-Fi Smart Plug | Wi-Fi Waterproof Smart Socket | Wi-Fi Smart Plug with Power Monitoring US Type | ZigBee Smart Plug US Type |
| SONOFF S26 | SONOFF S55 | SONOFF S31 | SONOFF S31 Lite zb |
| Wi-Fi Smart Wall Switch | Wi-Fi Smart Wall Socket US Type |
| SONOFF TX Series | SONOFF IW100/IW101 |
| Wi-Fi Smart LED RGB Light Strip | Wi-Fi Smart LED RGB Light Strip | Wi-Fi Smart RGB LED Bulb |
| SONOFF L1 | SONOFF L1 Lite | SONOFF B02/05-B |
| 433MHz RF Bridge | Wi-Fi Wireless Door/Window Sensor | ZigBee Bridge |
| SONOFF RF Bridge | SONOFF DW2-Wi-Fi | SONOFF ZB Bridge |
| Wireless Switch | Temperature and Humidity Sensor | Motion Sensor | Wireless Door/Window Sensor |
| SONOFF SNZB-01 | SONOFF SNZB-02 | SONOFF SNZB-03 | SONOFF SNZB-04 |
