We’re excited to introduce the latest updates in eWeLink App V5.21, bringing enhanced control, customization, and automation to your smart home. Whether you’re managing devices from your Wear OS Watch or creating smarter automations, this release is packed with features designed to make life easier and more connected. Let’s dive into what’s new!
The all-new Prime Plan takes the Advanced membership a step further, offering enhanced device control, higher sharing limits, and exclusive tools designed for power users.
Prime Plan Highlights
Prime subscriptions are available in the eWeLink App (V5.21). Web subscriptions will launch later in December.
Now, Android users can sync and control eWeLink-supported devices and manual scenes directly from their Wear OS watches.
After pairing your smartwatch via Profile > Wear OS Watches in the eWeLink App, you can conveniently sync and control your devices and scenes.
Once connected, you can:
Example: While getting ready for bed, you can tap the “Good Night” scene on your watch — instantly turning off all lights and closing the curtains, all without reaching for your phone.
Supported Devices of This Function Include:
Single-Channel Plug_Support 2.4G eWeLink-Remote | SONOFF BASICR4 SONOFF MINIR3 SONOFF MINIR4 SONOFF S40 lite CK-BL602-4SW-AY |
Three-Channel Switch | SONOFF T1 3C SONOFF TX3C |
Dual-Channel Plug | SONOFF DUALR2 |
Power detection Plug | SONOFF IW100_US SONOFF IW101_US SONOFF Pow R2 SONOFF POWR3 SONOFF S31 PSA-X67-GL |
Temp & Humi Monitoring Smart Switch | SONOFF S22_CN SONOFF TH10 SONOFF TH16 PSA-BHA-GL |
Multi-Functional Dual-Channel Power Detection Switch | SONOFF DUALR3 |
(POWCT)POWR3 – with LCD Screen | SONOFF POWCT SONOFF POWR316 SONOFF POWR320D SONOFF S60TPF SONOFF S60TPG |
Temperature & Humidity Monitoring Switch_Support with History Feature | SONOFF TH16R3 SONOFF THR316 SONOFF THR320 SN-ESP32D0-THR3-01 |
Single-Channel Plug-Multi-channel version | SONOFF Micro |
RGBCW LED Bulb Light, with 2.4G eWeLink-Remote | SONOFF B05-BL CK-BL602-5PWM-01 |
Create intelligent automations that trigger only when a device stays on or off for a specific duration. This new logic is perfect for energy savings, appliance monitoring, and convenience, and it now supports popular devices like switches and power monitoring plugs.
How It Works:
Practical Examples for Everyday Life:
Android users can now add Device Control and Sensor View widgets for a broader range of devices.
From checking your room temperature to turning on your heater with a single tap, widgets make your smart home faster and more accessible—right from the home screen.
Newly Supported Devices of This Function Include:
WiFi Smart Circuit Breaker | CK-BL602-DLQ-01 |
Zigbee Smart Water Valve | SONOFF SWV-NH SONOFF SWV-BSP |
Smart Roller Shutter Switch | SONOFF SN-ESP32D0R2-RBS-01 |
Zigbee Smart Plug | SONOFF SN-TLSR8656-S60-01 |
Zigbee Smart Wall Switch_Single-Channel Switch _Support OTA (Supports both No Neutral and Neutral Wire) | SONOFF ZBM5-1C-120 |
Zigbee Smart Wall Switch_Dual-Channel Switch _Support OTA(Supports both No Neutral and Neutral Wire) | SONOFF ZBM5-2C-120 |
Zigbee Smart Wall Switch_Three-Channel Switch _Support OTA(Supports both No Neutral and Neutral Wire) | SONOFF ZBM5-3C-120 |
Air Quality Monitor | SONOFF SAWF-08P |
Zigbee Temperature and Humidity Sensor | SONOFF SNZB-02LD SONOFF SNZB-02WD |
Customize device icons to better match your home setup! Added options now include:
Find these under Device Settings > Display As. This simple visual touch makes your device dashboard clearer and easier to navigate.
eWeLink App V5.21 reflects our continued mission to make smart home technology seamlessly blend into everyday life.
Whether you’re exploring automation with duration-based triggers, setting up your smartwatch for instant control, or enjoying the premium features of the new Prime Plan, your smart home now adapts more closely to the way you live.
Update to the eWeLink App V5.21 today and experience a smarter, more intuitive connected home. The new version has been submitted to Google Play and will roll out gradually over the next few days. iOS users—hang tight, the update is expected to arrive by the end of November.
