eWeLink App V5.17 delivers two key upgrades to improve your smart home experience: spot and fix broken scenes with missing devices, and seamless integration with Google Home devices. Now, when a deleted device prevents a scene from functioning properly, the scene will be clearly marked as invalid. Meanwhile, syncing and controlling Google Home devices directly from eWeLink makes cross-platform control easier than ever.
Tired of automations silently failing after a device is removed? With this update, scenes that are no longer functional due to deleted devices will now be clearly labeled as Invalid, giving you an instant heads-up and a chance to fix them.
Previously, when you deleted a device, you might not have realized that its associated scenes had stopped working. Now, eWeLink flags affected scenes to help you maintain a stable smart home setup—no more guesswork.
Only scenes that can no longer run properly due to a deleted device will be marked as “Invalid”, helping you quickly spot and fix broken automations.
Here’s how it works in common situations:
If the deleted device is re-added to your account, eWeLink may auto-repair the scene after a refresh. Once restored, auto scenes will stay disabled until you turn them back on, while manual scenes can be used right away.
eWeLink now supports syncing and controlling Google Home devices directly within the app, leveraging Google Home APIs to integrate devices from the Google Home Matter fabric. This eliminates the need to switch platforms while expanding your control options—whether you prefer voice commands via Google Home or centralized management in eWeLink.
Currently, synced Matter devices include Matter lights with dimmable, cool-warm, and colorful capabilities, with support for more device types coming soon.
Link Google Home Households
Synced Devices and Structure
Flexible Device Management
Add New Devices via a Synced Home
eWeLink app V5.17 brings smarter scene management and better cross-platform control. Easily spot and fix broken scenes affected by deleted devices and enjoy seamless control of your Google Home devices within eWeLink.
The new version has been submitted to Google Play and will roll out gradually over the next few days. iOS users—hang tight, the update is expected to arrive by the end of June.
