The latest eWeLink App 5.14 update introduces two powerful enhancements to scene functionality, making automation setup faster and more flexible than ever.
Setting up smart scenes has never been easier! With the new Manual Scene Duplication feature, you can instantly copy an existing Manual Scene directly from its editing page, saving you time and effort.
Imagine you’ve already created a scene that turns off all the lights and appliances before bedtime. Now, you want a similar scene for when you leave home. Instead of building it from scratch, simply duplicate the existing scene and adjust a few settings. This feature streamlines the process, ensuring you can set up automation faster and with minimal effort.
Greater flexibility comes to your smart home setup! Certain supported plugs, switches, and lights can now function as both a Trigger and an Action in the same smart scene.
Imagine you have a smart light switch in your hallway. When you manually turn it on, it can also trigger a smart plug that powers a shoe cabinet light. After a few minutes, both the switch and the plug can automatically turn off, ensuring energy efficiency.
This enhanced functionality now applies to a wide range of devices, including:
Wi-Fi Smart Switch with Energy Monitoring | SONOFF IW100_US SONOFF IW101_US SONOFF Pow R2 SONOFF POWR3 SONOFF S31 PSA-X67-GL |
Temp & Humi Monitoring Smart Switch | SONOFF S22_CN SONOFF TH10 SONOFF TH16 PSA-BHA-GL |
Single-Channel Plug-Multi-channel version | SONOFF Micro |
RGBCW LED Bulb Light, with 2.4G eWeLink-Remote | SONOFF B05-BL CK-BL602-5PWM-01 |
Zigbee Smart Switch | SONOFF S26R2ZBTPG |
| Smart Plug with Power Monitoring | SONOFF Pow |
GSM Single-Channel Plug – Multi-channel protocols | GSB-MSW-01 |
Rhythmic Strip Light | SONOFF L1 PSF-BTA-GL |
Dual-Color Cold and Warm Light_Support with tuning and scenes | SONOFF B02-B SONOFF B02-F |
RGBCW LED Light_Support with tuning and scenes | SONOFF B05-B WTW-SNL-05 |
Zigbee Single-Channel Switch _Support OTA | SONOFF ZBMINI-L SONOFF ZBMINIL2 |
Wi-Fi Smart LED RGB Light Strip | SONOFF L2 SONOFF L3-5M OPL-LED-01 SN-OPL1200-L3RGB |
Wi-Fi/2.4G 1C Plug, support eWeLink-Remote Gateway | CK-BL602-4SW-HS-02 |
Wi-Fi Smart Dimmer Switch | SONOFF D1 SONOFF D1R1 SONOFF Dimmer PSF-BLA-GL |
RGBCW LED Bulb Light | SONOFF B1 CKDK-001 LA-5CUI |
ZigBee Smart Plug | SONOFF ZCL_HA_DEVICEID_MAINS_POWER_OUTLET2 |
With these expanded automation options, your smart home setup becomes more dynamic and responsive to your daily routines. Upgrade to eWeLink App 5.14 today and take your smart scene automation to the next level!
