Try Floor Plan for Free with a Sample Layout
Security for a smartphone is never enough. How do we prevent people from prying into our App in our smartphone?
With a simple pattern based lock you can prevent any unauthorized access to eWeLink App. Pattern lock is a combination of moves between a grid of nine dots which is used as a password. Not only is it far more difficult to crack relative to text passwords, it is also much easier to feed into the device. So here’s how you can set one up for eWeLink App in no time.
Step 1. Open eWeLink App, select Profile
Step 2: Tap the button on the upper right
Step 3: Select Pattern Lock
Step 4: Create your pattern and comfirm it
(Note:your pattern should connect at least 4 dots)
Step 5: Your pattern lock has been successfully set up
Step 6: You can click here to turn on/off and change the unlock pattern
That’s all. After that, whenever you will open eWeLink App it will ask show you pattern lock like Android and by verifying the pattern you created in your settings you’ll be able to enter it.
