Device Control Widgets for iOS 17 & 18 Now Support More Devices
Table of Contents
The eWeLink App V5.10.1 introduced the highly anticipated Device Control Widget for iOS users, revolutionizing how you interact with your smart home. Compatible with iOS 17 and 18, this feature allows you to manage your favorite devices directly from the home screen, saving time and making smart home control effortless. Building on this foundation, eWeLink App V5.11 expands support to include an even wider range of devices, with plans to extend compatibility further in upcoming releases.
iOS widget
What's New in V5.11?
With the latest update, you can now control additional devices directly through the widget. The expanded list includes a variety of device types, such as smart plugs or switches, catering to both single- and multi-channel configurations.
Newly Supported Devices Include:
Device Type
Product Name
Single-Channel Plug-Multi-channel version
SONOFF Micro, SONOFF Micro-CFH, SONOFF Micro-MFG, SONOFF Micro-MFG-ESP
POWR3 with LCD Screen
SONOFF POWR316D, SONOFF POWR320D,
SONOFF POWR316,
SONOFF POWR320, SONOFF S60TPF, SONOFF S60TPG, SONOFF POWCT, SONOFF POWR325D
HMI Wall Switch
SONOFF NSPanel
Power Monitoring Plug Overload Alert—Multi-Channel Protocols
SONOFF S40, SONOFF S40TPB, SONOFF S40TPA
Power Detection Single-Channel Plug
Maker Sonoff Pow, SONOFF Pow
Three-channel Plug
SONOFF SA-025-3C
Single-Channel Switch_Support 2.4G eWeLink-Remote
SONOFF M5-1C,SONOFF T5-1C,SONOFF M5-1CH,SONOFF M5-1C-80,SONOFF M5-1C-86,SONOFF M5-1C-120,SONOFF M5-1C-80W,SONOFF M5-1C-86W,SONOFF M5-1C-120W
Three-Channel Switch_Support 2.4G eWeLink-Remote
SONOFF M5-3C,SONOFF T5-3C, SONOFF M5-3CH, SONOFF M5-3C-80, SONOFF M5-3C-86, SONOFF M5-3C-120, SONOFF M5-3C-80W, SONOFF M5-3C-86W, SONOFF M5-3C-120W
Dual-Channel Switch_Support 2.4G eWeLink-Remote
SONOFF M5-2C,SONOFF T5-2C,SONOFF M5-2CH,SONOFF M5-2C-80,SONOFF M5-2C-86,SONOFF M5-2C-120,SONOFF M5-2C-80W,SONOFF M5-2C-86W,SONOFF M5-2C-120W,SONOFF S50TPB
Single-Channel Touch Switch
SONOFF T5-1C-86, SONOFF T5-1C-80, SONOFF T5-1C-120
Dual-Channel Touch Switch
SONOFF T5-2C-120, SONOFF T5-2C-86, SONOFF T5-2C-80
Three-Channel Touch Switch
SONOFF T5-3C-86, SONOFF T5-3C-120, SONOFF T5-3C-80
Four-Channel Touch Switch
SONOFF T5-4C-86, SONOFF T5-4C-120, SONOFF T5-4C-80
With the release of V5.11, the list of supported devices has grown even further. Looking for devices added in earlier versions? Check the list of devices supported since App V5.10.1 here.
Why Use the Device Control Widget?
The Device Control Widget is designed to make smart home management easier and faster. By integrating it into your iPhone’s home screen, you can:
  1. Instant Access: Control up to 8 devices without opening the app.
  2. Customizable Layout: Choose between different widget sizes (4×4, 4×2, and 2×2) to fit your home screen.
  3. Efficient Management: Arrange devices in your preferred order for seamless navigation.
For example, with the Device Control Widget, you can effortlessly turn on your smart plug to power your coffee machine in the morning or switch off the wall switch to cut off the lights as you head out.
How to Set Up the Device Control Widget on iOS 17 & 18
Adding the widget to your home screen is a simple process:
  1. Long press anywhere on your home screen to enter edit mode.
  2. Tap “Edit” and then “Add Widgets.”
  3. Search for “eWeLink” and select your preferred widget size.
  4. Configure the widget by selecting up to 8 devices for display.
  5. Arrange your devices in the desired order and enjoy instant control.
Looking Ahead
eWeLink continues to innovate with plans to support even more device types in future updates. Whether you’re streamlining device control or simplifying daily routines, the Device Control Widget offers unparalleled convenience at your fingertips.
Share the Post:
Related Posts
