Seamless Monitoring & Control: A Guide to eWeLink Camera Live View
Table of Contents
Keeping an eye on your home shouldn’t feel complicated. Whether you’re checking your front door, your pets, or just making sure everything’s in order, quick access matters.
Camera Live View brings real-time monitoring and instant device control together on a single screen. Imagine noticing unusual movement in your backyard at night. You need to trigger a siren or floodlight immediately, but exiting the live feed to find the right switch in a long device list costs you precious seconds. Camera Live View eliminates this “screen hopping,” keeping you in control when every second counts.
Camera Live View
What is Camera Live View?
Available via the Insight tab, the “Camera Live View” feature combines real-time monitoring with active device control on a single, responsive screen:
  • Instant Live Feeds: View your cameras directly in the Insight -> Camera Live View section. You can effortlessly swipe to view up to 3 different live feeds.
  • Monitor & Control: Link and control your devices, such as outdoor lights, switches, or curtains, right below the live feed on one screen.
  • Seamless Live Transitions: Your streams stay active in the background for instant, seamless transitions as you swipe.
It’s about making your smart home faster, more intuitive, and more efficient.
Get Started with Camera Live View
Before you start, ensure you have the following checked for a smooth setup:
  • App Version: Update to eWeLink V5.14 or later.
  • Compatibility: Have your eWeLink-supported cameras and controllable devices (switches, plugs, curtains, etc.) ready.
  • Device Status: Ensure your cameras and controllable devices are online and responsive in the eWeLink app.
Compatible Device Reference
Camera Live View is compatible with a wide range of smart devices. Below are some of the supported categories and model examples:
Supported Cameras:
Cameras Types
Eligible Camera Models
Wi-Fi IP Security Camera
SONOFF GK-200MP2-B
SONOFF CAM-S2
SONOFF CAM-S2W
Indoor Pan-tilt Security Camera
SONOFF CAM-PT2
Outdoor Security Camera
SONOFF CAM-B1P
You can also use the following as cameras:
  • eWeLink Camera App: Turn an idle Android phone into a functional security camera.
  • eWeLink CAST: Turn your tablet into a live monitoring camera via the eWeLink CAST app.
Supported Controllable Devices
Device Type
Eligible Device Models (Examples)
Single-Channel Plug
SONOFF BASIC_R3
SONOFF MINI
SONOFF RF_R2
SONOFF S20R1
SONOFF S26
SONOFF S31 Lite
SONOFF S55R1
SONOFF S30
AIB-xU1
CKCP-001
Single-Channel Plug_Support 2.4G eWeLink-Remote
SONOFF BASICR4
SONOFF MINI-D
SONOFF MINIR3
SONOFF MINIR4
SONOFF S40 lite
BL1-S04-01
CK-BL602-4SW-AY
DIY Smart Switch
SONOFF Basic
SONOFF RF
SONOFF SV
Single-Channel Switch
SONOFF RF R2
SONOFF T1 1C
SONOFF Touch
SONOFF TX1C
Four-Channel Plug
SONOFF 4CH
Power detection Plug
SONOFF IW100_US
SONOFF IW101_US
SONOFF Pow R2
SONOFF POWR3
SONOFF S31
GSA-D76
PSA-X67-GL
Three-Channel Switch
SONOFF T1 3C
SONOFF TX3C
CKA-DM4-GL
Dual-Channel Switch
SONOFF T1 2C
SONOFF TX2C
Thermostat
SONOFF S22_CN
SONOFF TH10
SONOFF TH16
CK-BL602-TC-01
PSA-BHA-GL
Dual-Channel Plug
SONOFF DUALR2
CKW04-2C
Multi-Functional Dual-Channel Power Detection Switch
SONOFF DUALR3
E32-2SW-P0
Power Monitoring Plug Overload Alert – Multi-Channel Protocols
SONOFF S40
SONOFF S40TPA
SONOFF S40TPB
CK-BL602-SWP1-01
Single-Channel Plug-Multi-channel version
SONOFF Micro
CKAM1
(POWCT) POWR3 – with LCD Screen
SONOFF POWCT
SONOFF POWR316
SONOFF POWR320D
SONOFF S60TPF
SONOFF S60TPG
SN-ESP32D0-POWR3-01
Temperature & Humidity Monitoring Switch_Support with History Feature
SONOFF TH16R3
SONOFF THR316
SONOFF THR320
CK-BL602-W302SE10-01
RGBCW LED Bulb Light, with 2.4G eWeLink-Remote
SONOFF B05-BL
BL1-ALL-LED
CK-BL602-5PWM-01
HMI Wall Switch
SONOFF NSPanel
E32-MSW-NX
Four-Channel Plug_Support 2.4G eWeLink-Remote
BL1-S04-01
CK-BL602-4SW-HS
Zigbee Smart Switch
SONOFF S26R2ZBTPG
Smart Plug with Power Monitoring
SONOFF Pow
Curtain Motor
CK-BL602-DDCL-01
Display Camera Live View in Insight
  1. Navigate to the Insight tab.
  2. Tap the “” icon to access settings.
  3. On the Insight Settings screen, tap “Set” to select the sections.
  4. Find Camera Live View and add it to display on Insight.
  5. Tap Save” to confirm and return to the Insight screen.
Now, the Camera Live View section is ready for further configuration within your Insight tab.
Add Your Camera Feeds
  1. Tap the Camera Live View section on the Insight screen.
  2. Tap “Got it” on the introduction page to access the selection list.
  3. Tap “Set” in the top-right corner to edit your view.
  4. Select the cameras you want to view.
  5. Tap “Save” to finish. Swipe to view all added camera live feeds on the Insight screen.
  6. For future changes, simply tap the Settings icon in the top-right of the Camera Live View section to add, remove, or reorder your cameras.
Link and Control Your Devices
  1. Tap on any live feed of the cameras.
  2. On the camera monitoring page, tap “Edit” in the top-right corner to access the supported device list.
  3. Check the devices you want to link (e.g., lights or switches).
  4. Then, tap “Save” to complete the binding.
  5. Now, your linked devices will appear below the live feed. You can toggle them on/off while keeping a constant eye on the live stream.
Want to take your monitoring to the next level? Try eWeLink WEB to monitor up to 3 live feeds simultaneously on a single, larger screen for a more comprehensive view. (Requires an eWeLink Advanced/Prime Plan subscription)
You’re all set!
With Camera Live View, you can experience a smarter, safer home, making your daily monitoring and control simpler, more intuitive, and more efficient. Enjoy the effortless control right at your fingertips!
What important features are we missing? We’d love to hear from you! Join our discussion here
Share the Post:
Related Posts
