eWeLink CUBE Add-on Guide
eWeLink Smart Home
Control your eWeLink-supported devices via CUBE-based hardware (like SONOFF iHost).
- Navigate to the ‘Docker’ menu on the left
- Tap ‘+’ on the upper right and search for eWeLink Smart Home
- Select eWeLink/eWeLink-smart-home and add it
- Tap ‘RUN’ to open the settings, select network as ‘Host’ and fill in other parameters according to your needs, then tap ‘RUN’
- Navigate to the ‘Web UI’ tab, log in with your eWeLink account.
- Tap the ‘Sync’ button on your devices to sync them to iHost.
Not under your account: Check if this device was shared with you by someone else.
Not supported: Device with LAN-control feature will be supported one by one. Learn more
FAQ
Q: What device does it support?
A: Device with LAN-control feature.
Q: How to check if a device supports LAN control?
A: In eWeLink app, enter the device page, and go to device settings, the “LAN Control” option indicates that this feature is supported, please enable it.
