The foundation and the heart of your local smart home platform.
Table of Contents
Open API document
1. Start to Use
1.1 Preparation
Take SONOFF iHOST as an example.
Step 1.
Please make sure the gateway (iHost) is powered on and works properly.
The BLUE led indicates a normal network connection.
The RED led indicates an abnormal network connection.
Step 2.
Make sure the gateway and the PC are connected to the same LAN. Then enter the URL http://ihost.local on your browser.
Note:
If you have several gateways, you can get the corresponding IP address to access the specified gateway in the below two ways.
1. Log in to your wireless router and check the IP address of the gateway in DHCP.
2. iHost supports local discovery via mDNS.
1.2 Get started
  • Call the [Access Token] interface, and get an error response, prompting to click <Done>.
    Note that after pressing, the interface access is valid for no more than 5 minutes.
					// Request
curl --location --request GET 'http://<ip address>/open-api/v1/rest/bridge/access_token' --header 'Content-Type: application/json'
// Response
  "error": 401,
  "data": {},
  • Click <Done> and call the [Access Token] interface again. The response is successful, and the token is obtained.
					// Request
// Response
  "error": 0,
  "data": {
  "message": "success"
  • Verify token. Call the [Get Device List] interface. The response is successful, and the device list is obtained.
					// Request
curl --location --request GET 'http://<ip address>/open-api/v1/rest/devices' \
// Response
  "error": 0,
  "data": {
    "device_list":  [
        "name": "device name",
        "manufacturer": "manufacturer name",
        "model": "model name",
        "firmware_version": "1.1.0",
        "display_category": "switch",
        "capabilities": [
            "capability": "power",
            "permission": "readWrite"
        "protocal": "zigbee",
        "state": {
          "power": {
            "powerState": "on"
        "tags": {
          "key": "value"
        "online": true
Get iHost access token method:
After calling the [Access Token] interface, the iHost Web console page global pop-up box prompts the user to confirm the acquisition of the interface call credentials.
Note:
If you open more than one iHost web console page, the confirmation pop-up box will appear on multiple web console pages together, and the pop-up box of other web console pages will be closed after clicking the confirmation on one of the web console pages.
2. Core Concept
2.1 Development Interface Address
The gateway Web API interface has two access methods (based on IP or domain name), usually, the root path is /open-api/v1/rest/< specific function module >
// IP access
http://<IP address>/open-api/v1/rest/bridge
// Domain name access
http://<domain address>/open-api/v1/rest/bridge
2.2 Device Display Category & Capabilities
  • Device display category (DisplayCategory). Device display category is used to identify (device) specific categories, such as switch, plug, light, etc. This information will determine the UI display effect of the device in the gateway.
  • Device Capability. Device capability is used to describe the specific sub-functions of the device. Such as power control, brightness control, color temperature control, etc. A single device can support 1 or more capabilities.
    • Ability name. Identify a specific capability. For example power, and brightness.
    • Ability permission. Identify whether the capability supports reading or writing.
      • Read-only (read). Obtain the status value or configuration information related to this capability. For example, the states of power are on (open) and off (closed).
      • Write-only (write). Update the status value or configuration information related to the capability. For example, the power status can be changed to off through the interface.
      • Read&Write (readWrite). This capability supports both reading and writing.
					// Device capabilities description
  "capabilities": [
    // Power control
    // Brightness adjustment
      "capability": "brightness",
// Obtain the status state structure returned by the device list interface
  "state":{
    "[capability]": {
        "[capabilityState]":[value]
  "state": {
    "power": {
        "powerState": "on"
    "brightness": {
        "brightness": 100
// Modify device state - power off
  "state": {
    "power": {
        "powerState": "off"
3.Web API
Types of Data
Type Description
string
String data type. UTF8 encoded.
number
Number data type. double-precision 64-bit binary format IEEE 754
int
Integral data type.
object
Object data type. JSON-compliant object string[] Array of string
string[]
Array of string
int[]
Array of integral
object[]
Content
bool
Boolean
date
Time string. String in ISO (ISO 8601 Extended Format) format: YYYY-MM-DDTHH:mm:ss.sssZ. The time zone is always UTC (Coordinated Universal Time), identified by a suffix "Z".
Generic Response Results
Attribute Type Optional Description
error
int
N
Error code:
0: Success
400: Parameter error
401: Authentication failed
500: Server exception
data
object
N
Response data body
message
string
N
Response description:
When error is equal to 0, the content is success.
When error is not equal to 0, it is a non-empty string, and the content is an error description.
Response Example:
  "error": 0,
  "data": {
  "error": 400,
  "data": {},
Resource List
Item Description
Supported sound
- alert1 (Alarm Sound 1)
- alert2 (Alarm Sound 2)
- alert3 (Alarm Sound 3)
- alert4 (Alarm Sound 4)
- alert5 (Alarm Sound 5)
- doorbell1 (Doorbell Sound 1)
- doorbell2 (Doorbell Sound 2)
- doorbell3 (Doorbell Sound 3)
- doorbell4 (Doorbell Sound 4)
- doorbell5 (Doorbell Sound 5)
- alarm1 (Alarm Sound 1)
- alarm2 (Alarm Sound 2)
- alarm3 (Alarm Sound 3)
- alarm4 (Alarm Sound 4)
- alarm5 (Alarm Sound 5)
Supported deep
- bootComplete (System startup completed)
- networkConnected (Network connected)
- networkDisconnected (Network disconnected)
- systemShutdown (System shutdown)
-deviceDiscovered (Discover device)
- system Armed (System armed enable)
- system Disarmed (System armed disable)
- factoryReset (Reset device)
3.1 The Gateway Function
a. Access Token
Allow users to access token.
💡Notice: The token will be cleared after device reset.
  • URL/open-api/v1/rest/bridge/access_token
  • MethodGET
  • Header
    • Content-Type: application/json
Request Parameters: none
Successful data response:
token
string
N
The interface access token. It's valid for a long time, please save it.
Condition: User trigger the < command key > and access this interface within the valid time.
Status Code: 200 OK
Response Example:
  "error": 401,
  "data": {},
b. Get the State of Gateway
Allow authorized users to obtain the status of gateway through this interface
  • URL: /open-api/v1/rest/bridge/runtime
  • Method: GET
  • Header:
    • Autorization: Bearer <token>
ram_used
int
N
ram usage percent.[0-100]
cpu_used
int
N
cpu usage percentage. [0-100]
power_up_time
date
N
The last power-on time
  • Conditions: The request parameters are legal, and the user identity verification is passed.
    Status Code: 200 OK
Response Example:
  "error": 0,
  "data": {
    "ram_used": 40,
    "cpu_used": 30,
    "power_up_time": "2022-10-12T02:58:09.989Z"
c. Set the Gateway
Allow authorized users to set the gateway through this interface​
    • URL: /open-api/v1/rest/bridge/config
    • Method: PUT
    • Header:
Request parameters:
volume
int
Y
System volume. [0-100]
Successful data response:empty Object {}
Status Code: 200 OK
Response Example:
  "error": 0,
  "data": {},
3.2 Hardware Function
a. Restart Gateway (iHost)
Allow authorized user to restart the gateway through this interface
  • URL: /open-api/v1/rest/hardware/reboot
  • Method: POST
  • Header:
Successful data response: empty Object {}
Status Code: 200 OK
  "error": 0,
  "data": {},
b. Speaker Control
Allow authorized users to control the speaker through this interface
    • URL: /open-api/v1/rest/hardware/speaker
    • Method: POST
    • Header:
      • Authorization: Bearer <token>
Request parameters:
type
string
N
Optional parameters:
1.play_sound (play the sound)
2.play_beep (play the beep)
sound
SoundObject
Y (N if type is play_sound.)
The sound.
beep
BeepObject
Y (N if type is play_beep.)
The beep
SoundObject Object
name
string
N
The sound name. The supported values can be checked in [Resource List - Supported sound]
volume
int
N
The sound volume. [0-100]
countdown
int
N
The duration for the speaker to play the sound, and it will stop playing automatically after the time is up. Unit: second. [0,1799]
BeepObject Object
name
string
N
The beep name. The supported values can be checked in [Resource List - Supported deep]
volume
int
N
The beep volume. [0-100]
Status Code: 200 OK
Response Example:
  "error": 0,
  "data": {},
3.3 Device Management Function
a. Supported Device Type
Device TypeValue
Plugplug
Switchswitch
Lightlight
Curtaincurtain
Door/Window SensorcontactSensor
Motion sensormotionSensor
Temperature sensortemperatureSensor
Humidity sensorhumiditySensor
Temperature and humidity sensortemperatureAndHumiditySensor
Water leak detectorwaterLeakDetector
Smoke detectorsmokeDetector
Wireless buttonbutton
Cameracamera
General sensorsensor
b. Supported Device Capabilities
Name
Description
Capability&Permission Example
Attribute(Status)
Protocol(Status inquiry&Control command)
power
Power control
[ { “capability”: “power”, “permission”: “readWrite” }]
{ “powerState”: “on”, //The field powerState indicates the power on/off state, which is required. string type, ”on“ means on, ”off“ means off, ”toggle“ means reverse.}
Turn on:{ “powerState”: “on”}Turn off:{ “powerState”: “off”}
toggle
Toggle control
[ // Single toggle example { “capability”: “toggle”, “permission”: “readWrite”, “name”: “1” }, // Multiple toggle example[ { “capability”: “toggle”, “permission”: “readWrite”, “name”: “1” }, { “capability”: “toggle”, “permission”: “readWrite”, “name”: “2” }]
{ “toggleState”: “on”, // The field “toggleState” indicates the toggle state of the {name} attribute of {device_id}. Required. String type. “on” means open, “off” means close, “toggle” means reverse.}
toggle format is special{ [capability] :{ [toggle-name]:{ [toggleState]:[value] } }}toggle 1 on, toggle 2 off{ “toggle”: { “1”: { “toggleState”: “on” }, “2”: { “toggleState”: “off” } }}
brightness
Brightness Control
[ { “capability”: “brightness”, “permission”: “readWrite” }]
{ “brightness”: 100, // The field “brightness” indicates the percentage of brightness. Int type. An integer with a value range of 0~100.}
0 is the darkest and 100 is the brightest. Set the brightness to 80%. { “brightness”: { “brightness”: 80, }}
color-temperature
Color temperature control
[ { “capability”: “color-temperature”, “permission”: “readWrite” }]
{ “colorTemperature”: 100, // 字段 “colorTemperature” Indicates the percentage of color temperature. Int type. An integer with a value range of 0~100. 0 means warm light, 50 means neutral light, and 100 means cold light.}
Set the Color temperature to 80%. { “color-temperature”: { “colorTemperature”: 50 }}
color-rgb
Color control
[ { “capability”: “color-rgb”, “permission”: “readWrite” }]
{ “red”: 255, // The field “red” represents red in the RGB color space. Required. Int type. An integer with a value range of 0~255. “green”: 0, // The field “green” represents green in the RGB color space. Required. Int type. An integer with a value range of 0~255. “blue”: 255, // The field “blue” represents blue in the RGB color space. Required. Int type. An integer with a value range of 0~255.}
Set the color.{ “color-rgb”: { “red”: 255, “green”: 0, “blue”: 255, }}
percentage
Percentage control
[ { “capability”: “percentage”, “permission”: “readWrite” }]
{ “percentage”: 100, // The field “percentage” represents a percentage of a certain degree, and the field percentageDelta can be selected as one of the two. int type. An integer with a value range of 0~100.}
Set to 40%{ “percentage”: { “percentage”: 40 }}
motor-control
Motor control
[ { “capability”: “motor-control”, “permission”: “readWrite” }]
{ “motorControl”: “stop”, // The field “motor-control“ indicates the open or close state of the motor。 Required. String type. Optional values, “open” (open), “close” (close), “stop” (stop), “lock” (lock).}
Turn on the motor{ “motor-control”: { “motorControl”: “open” }}
motor-reverse
Motor reverse
[ { “capability”: “motor-reverse”, “permission”: “readWrite” }]
{ “motorReverse”: true, // The field “motor-reverse” indicates the forward and reverse setting of the motor. Required. boolean type. true means forward rotation, false means reverse rotation.}
Set the motor reverse{ “motor-reverse”: { “motorReverse”: false }}
startup
Power on state (Power Supply)
[ { “capability”: “startup”, “permission”: “readWrite” }]
{ “startup”: “on” // String type. Required. Optional values, “on” (power on) ,“stay“ (stay power on),”off“ (power off)}
Set the power on state to always stay on when powered on{ “startup”: { “startup”: “on” }}
startup
Toggle power on state (can use with toggle)
[ { “capability”: “startup”, “permission”: “readWrite”, “components”: [ //Components that support power on retention. If the device with the toggle sub-channel needs to support power on retention, this field is mandatory. In particular, the toggle capability supports separate power-on retention settings. For details, see the update protocol of toggle. // toggle 1 power on state { “capability”: “toggle”, // String type. Required. Represents the name of the component capability that supports power-on retention. Only “power” and “toggle” are supported. “name”: “1”, // The field “name” indicates the attribute name that can be toggled. Required. String type. Only uppercase and lowercase letters and numbers are allowed. Taking the multi-channel switch as an example, it should be the channel number, that is, 1, 2, 3, 4 } ] }]
When channel 1 power on, the power state is always on{ “toggle”: { “1”: { “startup”: “on” } }}
camera-stream
Camera stream
{ “capability”: “camera-stream”, // The field “capability” indicates the name of the specific function. Rrequired. String type. camera-stream indicates the video streaming capability of the camera. “permission”: “read”, // The field “permission” indicates the use of specific functions. Required. String type. Optional values: “read” (readable), “write” (writable), “readWrite” (readable and writable)。 “configuration”: { “streamUrl”: “rtsp://<username>:<password>@<hostname>:<port>/streaming/channel01″, //stream url. String type. Required. } }
{ “camera-stream”: { “configuration”: { “streamUrl”: “rtsp://<username>:<password>@<hostname>:<port>/streaming/channel01″, // stream url. String type. Required. } }}
motor-clb
Motor calibration detection
[ { “capability”: “motor-clb”, “permission”: “read” }]
{ “motorClb”: “calibration”, // The field “motor-clb” indicates that the motor has been calibrated Required. String type, normal means normal mode (calibrated), calibration means it is being calibrated.}
The motor is being calibrated.{ “motor-clb”: { “motorClb”: “calibration” }}
detect
State detection
[ { “capability”: “detect”, “permission”: “read” }]
{ “detected”: true, // The field “detected” indicates the current detection result. Required. Boolean type, true indicates that the condition is detected, false indicates that the condition is not detected.}
The current state is the result detected.{ “detect”: { “detected”: true }}
humidity
Humidity detection
[ { “capability”: “humidity”, “permission”: “read” }]
{ “humidity”: 50, // The field “humidity” indicates the current relative humidity (percentage). Required. Int type. An integer with a value range of 0~100.}
Current humidity is 20{ “humidity”: { “humidity”: 20 }}
temperature
Temperature detection
[ { “capability”: “temperature”, “permission”: “read” }]
{ “temperature”: 26.5, // The field “temperature” indicates the current temperature. Required. Number type. The unit is Celsius.}
Current temperature is 20 Celsius{“temperature”: {“temperature”: 20}}
battery
Remaining battery detection
[{ “capability”: “battery”, “permission”: “read” }]
{ “battery”: 95, // The field “battery” indicates the percentage of remaining battery power. Required. Int type. An integer with a value range of -1~100. -1 means that the battery level is unknown.}
Current remaining power is 40.{ “battery”: { “battery”: 40 }}
press
Press detection
[ { “capability”: “press”, “permission”: “read” }]
{ “press”: “singlePress”, // The field “press” indicates the method of pressing the button. Required. String type. ptional values: “singlePress” (single-click/single short press), “doublePress” (double-click/two consecutive short presses), “longPress” (long press).}
A single click was detected{ “press”: { “press”: “singlePress” }}
rssi
Wireless signal strength detection
[ { “capability”: “rssi”, “permission”: “read” }]
{ “rssi”: -65, // The field “rssi” indicates the wireless signal strength (received signal strength indication). Required. int type. The unit is dBm, and the optional value is a negative integer.}
{ “rssi”: {“rssi”: -65 }}
c. Tags Description
  • The special key toggle is used to set the name of the toggle subcomponent.
    "toggle": {
        '1': 'Chanel1',
        '2': 'Chanel2',
        '3': 'Chanel3',
        '4': 'Chanel4',
  • The special key temperature_unit is used to set the temperature unit.
d. Special Error Code and Description
Error Code
Description
110000
The sub-device/group corresponding to the id does not exist
110001
The gateway is in the state of discovering zigbee devices
110002
Devices in a group do not have a common capability
110003
Incorrect number of devices
110004
Incorrect number of groups
110005
Device Offline
110006
Failed to update device status
110007
Failed to update group status
110008
The maximum number of groups has been reached. Create up to 50 groups
110009
The IP address of the camera device is incorrect
110010
Camera Device Access Authorization Error
110011
Camera device stream address error
110012
Camera device video encoding is not supported
110013
Device already exists
110014
Camera does not support offline operation
110015
The account password is inconsistent with the account password in the RTSP stream address
110016
The gateway is in the state of discovering onvif cameras
110017
Exceeded the maximum number of cameras added
110018
The path of the ESP camera is wrong
e. Search for Sub-device
Allow authorized users to enable or disable gateway search for sub-devices through this interface
  • 💡Note: Only supports searching for Zigbee sub-devices now.
  • 💡Note: Zigbee sub-devices will be added automatically after searching. Do not need to use the “Manually Add Sub-devices” interface
  • URL: /open-api/v1/rest/devices/discovery
  • Method: PUT
  • Header:
Request parameters:
Attribute
Type
Optional
Description
enable
boolean
N
true (Start paring);
false (Pause pairing)
type
string
N
Searching Type: Zigbee
Status Code: 200 OK
Response Example:
  "error": 0,
  "data": {},
f. Manually Add the Sub-device
Allow authorized users to add a single sub-device through this interface
info💡 Note: Only RTSP Camera and ESP32 Camera are supported now
  • Method: POST
  • Header
Request parameters:
Attribute
Type
Optional
Description
name
string
N
Sub-device name
display_category
string
N
Device Type. Only support camera。
capabilities
CapabilityObject[]
N
Capability list. When display_category = camera, capabilities only include camera-stream capabilities.
protocal
string
N
Device protocol. RTSP; ESP32-CAM
manufacturer
string
N
Manufacturer.
model
string
N
Device model
firmware_version
string
N
Device firmware version
CapabilityObject Object
Attribute
Type
Optional
Description
capability
string
N
Capability name. Only support “camera-stream”
permission
string
N
Device permission. Only support read.
configuration
Y
Camera stream configuration.
CameraStreamConfigurationObject Object
Attribute
Type
Optional
Description
stream_url
string
N
Stream url,<schema>://<hostname>:<port>/<username>:<password>@<service_path>,e.g.: rtsp://admin:[email protected]:554/streaming/channel01
schema optional
  • rtsp
  • http (For ESP32-Camera)
Note: Some cameras don’t have account numbers and passwords, so you can leave the username and password blank.
Attribute
Type
Optional
Description
serial_number
string
N
Device unique serial number
Status Code: 200 OK
Response Example:
  "error": 0,
  "data": {
Failure data response: empty Object
Condition
  1. Camera stream address access error (format error, authorization failure, network exception, etc.)
  2. Device already exists
  3. If a single device fails to add, returns all devices fail to add.
Status Code: 200 OK
Error code
● 110009 Camera IP address error
● 110010 Camera access authorization error
● 110011 Camera stream address error
● 110012 The Camera video encoding does not support
● 110013 Device already exists
● 110014 Camera offline
● 110015 The account password is inconsistent with the account password in the RTSP stream address
Response Example:
  "error": 110009,
  "data": {},
  "message": "camera ip access failed"
g. Get List of Sub-devices
Allow authorized users to obtain the list of gateway sub-device through this interface.
  • Method: GET
  • Header:
Attribute
Type
Optional
Description
serial_number
string
N
third_serial_number
string
“N” when a third-party device is connected, otherwise “Y”
Third-party device unique serial number
service_address
string
Third-party service address
name
string
N
Device name, if it is not renamed, will be displayed by the front end according to the default display rules.
manufacturer
string
N
Manufacturer
model
string
N
Device model
firmware_version
string
N
Firmware version. Can be an empty string.
hostname
string
Y
Device hostname
mac_address
string
Y
Device mac address
app_name
(ihost >= 1.3.1)
string
Y
The name of the application. If app_name is filled in when obtaining access token, this field will be written to all subsequent devices accessed through this token.
display_category
string
N
Device category
capabilities
CapabilityObject[]
N
Device capabilities
protocol
string
Device protocol: zigbee, onvif, rtsp, esp32-cam
state
object
Y
Device state object. For state examples of different capabilities, please check 【Support Device Capabilities】
tags
object
Y
JSON format key-value, custom device information. The function is as follows:– Used to store device channels– Used to store temperature units– Custom information for other third-party devices
online
boolean
N
Online status: True for onlineFalse is offline
subnet
boolean
Y
Whether it is in the same subnet as the gateway
Status Code: 200 OK
Response Example:
  "error": 0,
  "data":{
    "device_list":  [
        "name": "My Device",
        "manufacturer": "SONOFF",
        "model": "BASICZBR3",
        "capabilities": [
            "capability": "rssi",
            "permission": "read"
        "state": {
          "power": {
            "powerState": "on"
        "tags": {
          "key": "value"
        "online": true
h. Update Specified Device Information or State
Allow authorized users to modify the basic information of sub-device and issue control commands through this interface.
  • URL: /open-api/v1/rest/devices/{serial_number}
  • Method: PUT
  • Header:
Request parameters:
Attribute
Type
Optional
Description
name
string
Y
Device name
tags
object
Y
state
object
Y
Device state object. For state examples of different capabilities, please check [Support Device Capabilities]
configuration
object
Y
Capability configuration information, currently only the camera_stream capability supports modification.
Status Code: 200 OK
Error Code:
  • 110000 The sub-device/group corresponding to the id does not exist
  • 110006 Failed to update device status
Response Example:
  "error": 0,
  "data": {},
					import axios from 'axios';
(async function main() {
    // turn on device
    await axios({
        url: `http://ihost.local/open-api/v1/rest/devices/${serial_number}`,
        method: 'PUT',
        headers: {
        data: {
            state: {
                power: {
                    powerState: 'on'
i. Delete Sub-device
Allow authorized users to delete sub-devices through this interface.
  • Method: DELETE
  • Header:
Status Code: 200 OK
Response Example:
  "error": 0,
  "data": {},
4. Third-party Device Access
4.1 Access Instruction
Device Access
Third-party gateway Access
Access steps
  1. Determine the classification of the device in the gateway. For the detail please check the [Supported Device Type].
  2. Determine the capabilities that the device can access. For the detail please check the [Supported Device Capabilities].
  3. Request the [Discovery Request] interface to add the device to the gateway.
    • Attention: You need to provide the service address for receiving the instructions issued by the gateway, which is used to receive the device control instructions issued by the gateway.
  1. If the status of the third-party device changes, you need to call the [Device States Change Report] interface to send the latest status back to the gateway.
  2. After adding, the third-party device will appear in the Device List, with most of the functions of the gateway (other non-third-party devices). The common open interfaces related to the device can be used normally.
💡Select the appropriate device category. The classification will affect the final display result of the UI after the device is connected to the gateway.
💡Choose the right device capability. The capability list will determine the status of the device state protocol.
Program Process
a. Device Access
b. Third-party Gateway Access
4.2 Access Example
Switch, Plug
Sync third-party devices
					// Request Example
URL:/open-api/v1/rest/thirdparty/event
Method:POST
Header:
Body:
  "event": {
    "header": {
      "name": "DiscoveryRequest",
      "message_id": "Unique identifier, preferably a version 4 UUID",
      "version": "1"
    "payload": {
      "endpoints": [
          "name": "my plug",
          "display_category": "plug",
          "capabilities": [
              "permission" "readWrite"
          "state": {
            "power": {
              "powerState": "on"
          "tags": {
            "key": "value"
          "firmware_version": "firmware version",
					//Response Example
  "header": {
    "name": "Response",
    "version": "1"
  "payload": {
    "endpoints": [
Report device status
					//Request Example
Method:POST
Header:
Body:
  "event": {
    "header": {
      "version": "1"
    "endpoint": {
    "payload": {
       "state": {
        "power": {
          "powerState": "on"
					//Response Example
  "header": {
    "name": "Response",
    "version": "1"
  "payload": {}
Report offline/online
					//Request Example
  "event": {
    "header": {
      "version": "1"
    "endpoint": {
    "payload": {
       "online": true
					//Response Example
  "header": {
    "name": "Response",
    "version": "1"
  "payload": {}
Receive the instructions about the gateway control device
					//Request Example
URL:<service address>
Method:POST
Header:
B
  "directive": {
    "header": {
      "name": "UpdateDeviceStates",
      "version": "1"
    "endpoint": {
    "payload": {
       "state": : {
         "power": {
           "powerState": "on"
					//Response Example
  "header": {
    "name": "Response",
    "version": "1"
  "payload": {}
Query device
					//Request Example
URL:/open-api/v1/rest/devices
Method:GET
Header:
Body: none
					//Response Example
  "error": 0,
  "data": {
    "device_list": [
        "name": "my plug",
        "capabilities": [
        "state": {
          "power": {
            "powerState": "on"
        "tags": {
          "key": "value"
        "online": true
4.3 Web API
Third-Party Request Gateway Interface
Request Format
Allow authorized users to send event requests to the gateway through this interface.
  • URL: /open-api/v1/rest/thirdparty/event
  • Method: POST
  • Header:
Request parameters:
Attribute
Type
Optional
Description
event
EventObject
N
Request event object structure information
EventObject Object
Attribute
Type
Optional
Description
header
HeaderObject
N
Request header structure information
endpoint
EndpointObject
Y
Request endpoint structure informationNote: This field is empty when sync a new device list.
payload
PayloadObject
N
Request payload structure information
HeaderObject Object
Attribute
Type
Optional
Description
name
string
N
Request name. optional parameter: DiscoveryRequest: Sync new devices DeviceStatesChangeReport: Device status update report DeviceOnlineChangeReport: Device online status report
message_id
string
N
Request message ID, UUID_V4
version
string
N
Request protocol version number. Currently fixed at 1
EndpointObject Object
Attribute
Type
Optional
Description
serial_number
string
N
third_serial_number
string
N
tags
object
Y
JSON format key-value, custom device information. [Device Management Function] – [Tags Description]
PayloadObject Object:
According to the different header.name have different request structure.
Response Format
Status Code: 200 OK
Response parameters:
Attribute
Type
Optional
Description
header
HeaderObject
N
Response header structure information
payload
PayloadObject
N
Response payload structure information
HeaderObject Object
Attribute
Type
Optional
Description
name
string
N
Response header name. optional parameters:Response: Successful response ErrorResponse: Error response
message_id
string
N
Response header message ID, UUID_V4. Pass in the request message header.message_id here*If the request input parameter lacks message_id, this field will be an empty string when responding.
version
string
N
– Request protocol version number. Currently fixed at 1.
-Successful response–PayloadObject Object:
Depending on the request type, the response structure is different. For details, please refer to the specific request instruction document.
-Failure response–PayloadObject Object:
Attribute
Type
Optional
Description
type
string
N
Error Type: INVALID_PARAMETERS: Parameter error INTERNAL_ERROR :Service internal error
description
string
N
Error description
DiscoveryRequest
Sync a new device list
💡Note: After the device is synchronized to the gateway, it is online by default, that is, online=true. Subsequent online changes are completely dependent on synchronization with the third party through the DeviceOnlineChangeReport interface.
Request parameters:
None
Attribute
Type
Optional
Description
endpoints
EndpointObject[]
N
Device List
EndpointObject Object:
Attribute
Type
Optional
Description
third_serial_number
string
N
name
string
N
Device name
display_category
string
N
Device Category. See the [Supported Device Type] for details. *Three-party devices don’t support adding cameras now.
capabilities
CapabilityObject[]
N
Capabilities list
state
object
N
Initial state information
manufacturer
string
N
Manufacturer
model
string
N
Device model
tags
object
Y
JSON format key-value, custom device information:Be used to store device channelsBe used to store temperature unitsOther third-party custom data
firmware_version
string
N
Firmware version
service_address
string
N
Service address. Such as http://192.168.31.14/service_address
Example of Request :
					//Discovery
  "event": {
    "header": {
      "version": "1"
    "payload": {
      "endpoints": [
          "name": "my plug",
          "capabilities": [
          "state": {
            "power": {
              "powerState": "on"
          "tags": {
            "key": "value"
Attribute
Type
Optional
Description
endpoints
EndpointObject[]
N
Device list
Attribute
Type
Optional
Description
serial_number
string
N
third_serial_number
string
N
Example of a correct response:
  "header": {
    "name": "Response",
    "version": "1"
  "payload": {
    "endpoints": [
Example of an error response:
  "header": {
    "name": "ErrorResponse",
    "version": "1"
  "payload": {
    "type": "INVALID_PARAMETERS",
    "description": "webhook cannot be empty"
💡Note: Repeated status reports may falsely trigger associated scene.
Request parameters:
Attribute
Type
Optional
Description
state
object
N
Devicce state, See [Supported device cabilities] for detail
  "event": {
    "header": {
      "version": "1"
    "endpoint": {
    "payload": {
       "state": {
        "power": {
          "powerState": "on"
PayloadObject Object: Empty Object
Example of a successful response:
  "header": {
    "name": "Response",
    "version": "1"
  "payload": {}
Request parameters:
Attribute
Type
Optional
Description
online
boolean
N
Device online status true: Online false: Offline
  "event": {
    "header": {
      "version": "1"
    "endpoint": {
    "payload": {
       "online": true
  "header": {
    "name": "Response",
    "version": "1"
  "payload": {}
Interface for sending command via device service address
💡Note:
  1. The third-party needs to respond to the gateway’s request within 3s. Otherwise will be timeout.
Request format
Gateway sends commands to the third-party through the device service address interface.
  • URL<service address>
  • MethodPOST
  • Header
Request parameters:
Attribute
Type
Optional
Description
directive
DirectiveObject
N
Directive object structure information
DirectiveObject Object
Attribute
Type
Optional
Description
header
HeaderObject
N
endpoint
EndpointObject
N
payload
PayloadObject
N
HeaderObject Object
Attribute
Type
Optional
Description
name
string
N
Request name. Optional parameters:UpdateDeviceStates: Update device states
message_id
string
N
version
string
N
Attribute
Type
Optional
Description
serial_number
string
N
third_serial_number
string
N
tags
object
N
  "directive": {
    "header": {
      "version": "1"
    "endpoint": {
      "tags": {}
    "payload": {
      "state": {
        "power": {
          "powerState": "on"
Response format
HTTP Status Code: 200 OK
HTTP Response Attribute:
Attribute
Type
Optional
Description
event
EventObject
N
Response event structure information
EventObject Object
Attribute
Type
Optional
Description
header
HeaderObject
N
payload
PayloadObject
N
HeaderObject Object
Attribute
Type
Optional
Description
name
string
N
Response header name. Optional parameter: UpdateDeviceStatesResponse: Update device states response ErrorResponse: Error response
message_id
string
N
version
string
N
Attribute
Type
Optional
Description
type
string
N
Error type:– ENDPOINT_UNREACHABLE: Device is unreachable or offline– ENDPOINT_LOW_POWER: Device is in a low battery state and cannot be controlled– INVALID_DIRECTIVE: Command issued by the gateway is abnormal– NO_SUCH_ENDPOINT: Device doesn’t exist– NOT_SUPPORTED_IN_CURRENT_MODE: Current mode is not supported– INTERNAL_ERROR: Service internal error
Conditions: The request parameters are legal.
Status Code: 200 OK
Successful response
  "event": {
    "header": {
      "version": "1"
    "payload": {}
Successful response
  "event": {
    "header": {
      "version": "1"
    "payload": {
UpdateDeviceStates
Request parameters:
Attribute
Type
Optional
Description
state
object
N
Devicce state, See [Supported device cabilities] for detail.
  "directive": {
    "header": {
      "version": "1"
    "endpoint": {
    "payload": {
       "state": : {
         "power": {
           "powerState": "on"
PayloadObject Object:empty Object
Example of Successful Response
  "header": {
    "name": "Response",
    "version": "1"
  "payload": {}
Get Debug Logs Interface
Allow authorized users to obtain device debugging logs through this interface.
💡The Gateway log storage limit is as follows.
  1. event_log: Third-party report request log. A single device only saves the latest 3000 logs.
  2. directive_log: Gateway sends request logs. A single device only saves the latest 3000 logs.
💡You can download the interface access logs within the selected time range through this interface. The file name is {start timestamp}{end timestamp}{device serial number}.json, format is:
"message_id": "message_id", //Message ID
"ip": "", // Remote IP. Required.
"req": {  // Request record.
"method": "GET", //  Request method. Required.
"url": "", // Request url. Required.
"body": "", // Request body, json string.Required. An empty string is allowed.
"header": "" , // Request header, json string. Required.
"res": { // Response record.
		"status_code":  200, // Status code. Required.
"body": "" , // Response body, json string.Required. An empty string is allowed.
"header": "" , // Response header, json string. Required.}
  • URL: /open-api/v1/rest/thirdparty/debug-log/{serial_number}
  • Method: GET
  • Header:
Request parameters:
Attribute
Type
Optional
Description
type
string
N
Log type:event_log: Third-party report request logdirective_log: The directive log sent by the gateway
from_index
int
Y
Start sequence number. Default is 0. An integer in the range [0,3000].
start_time
date
Y
Start timestamp, query specific time. If empty, default is 1 minute ago.
end_time
date
Y
End timestamp, query specific time. If iempty, default is current time.
limit
int
Y
The limit messages to be pulled, the range is an integer of [1,50]. If empty, default is 50.
order
string
Y
Sort by time range,DESC: Descending orderASC: Ascending orderDefault is DESC
Successful Response
  • Status Code: 200 OK
    Response header
    • Content-Type: application/octet-stream
    • Content-Disposition: attachment; filename={Start timestamp}{End timestamp}{device serial number}.json
Abnormal response
  • Status Code:
    • 400 Parameter error
    • 500 Gateway service exception
5. Server-sent events
5.1 Instruction
The gateway supports pushing messages to the client using SSE (Server-sent events). The client can monitor SSE messages after obtaining the access credentials and can parse the content of the push messages according to the development interface event notification protocol after receiving the messages pushed by the gateway. It should be noted that the gateway currently uses the HTTP1.1 protocol, so SSE on the browser side there will be a maximum of no more than 6 connections limit (Specific instructions can be found in the MDN EventSource interface description.)
5.2 Common Format
    • URL:/open-api/v1/sse/bridge
    • MethodGET
Request parameters:
Name
Type
Optional
Description
access_token
string
N
Access Token
Note:
When requesting an SSE connection, the gateway will check the access_token, and it will return an authentication failure error if it is invalid. { “error”: 401, “data”: {}, “message”: “invalid access_token”}
<Module Name>#<Version>#<Message Type>
For example:
Module Name: device
Version: v1,v2,v3
Message Type: addDevice
Example:
					const evtSource = new EventSource("http://ihost.local/open-api/v1/sse/bridge?access_token=xxxxxx");
evtSource.addEventListener('device#v1#addDevice',function (event) {
  try {
    console.log('data', data);
  } catch (error) {
5.3 Device Module
a. Add Device Event
Module Name:device
Version:v1
Message Type:addDevice
event.data parameters
Name
Type
Optional
Description
payload
ResponseDeviceObjectObject – Interface the same with the Get Device List
N
device information
Example:
					//Event:device#v1#addDevice
// event.data
  "payload": {
    "name": "My device",
    "capabilities": [
    "state": {
      "power": {
        "powerState": "on"
    "tags": {
      "key": "value"
    "online": true
b. Update Device State Event
Module Name:device
Version:v1
Message Type:updateDeviceState
Name
Type
Optional
Description
endpoint
EndpointObject
N
Device Information
payload
object。 Structure the same as the device state
N
Device Status Data
Parameter
Type
Optional
Description
serial_number
string
N
Device unique Serial Number
third_serial_number
string
Y
The unique serial number of the third-party device. For devices connected through open interfaces, this field is required.
Example:
					//Event:device#v1#updateDeviceState
// event.data
  "endpoint": {
  "payload": {
    "power": {
      "powerState": "on"
    "brightness": {
      "brightness": 100
c. Update Device Info Event
Module Name:device
Version:v1
Message Type:updateDeviceInfo
Name
Type
Optional
Description
endpoint
EndpointObject
N
Device Information
payload
DeviceChangeObject
N
Device Change Data
Attribute
Type
Optional
Description
serial_number
string
N
third_serial_number
string
Y
DeviceChangeObject Object
Name
Type
Optional
Description
name
string
N
Device Name
Example:
					//Event:device#v1#updateDeviceInfo
// event.data
  "endpoint": {
  "payload": {
d. Delete Device Event
Module Name:device
Version:v1
Message Type:deleteDevice
Name
Type
Optional
Description
endpoint
EndpointObject
N
Device Information
Attribute
Type
Optional
Description
serial_number
string
N
third_serial_number
string
Y
Example:
					//Event:device#v1#deleteDevice
// event.data
  "endpoint": {
e. Update Device Online Event
Module Name:device
Version:v1
Message Type:updateDeviceOnline
Name
Type
Optional
Description
endpoint
EndpointObject
N
Device Information
payload
DeviceChangeObject
N
Device Change Data
Attribute
Type
Optional
Description
serial_number
string
N
third_serial_number
string
Y
Name
Type
Optional
Description
online
boolean
N
Device Online Status
Example:
					//Event:device#v1#updateDeviceOnline
// event.data
  "endpoint": {
  "payload": {
    "online": false
